查看: 1489|回复: 3
新手求教,请大神帮忙看看这个卡能复制不?
发表于 2023-10-3 08:39:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
第一次用PN654pro,请帮忙看看下面这个卡有复制的机会没?
Found Mifare Classic 1k tag
Uid :41FEE7CF
ISO/IEC 14443A (106 kbps) target:
    ATQA (SENS_RES): 00  04
* UID size: single
* bit frame anticollision supported
       UID (NFCID1): 41  fe  e7  cf
      SAK (SEL_RES): 28
* Compliant with ISO/IEC 14443-4
* Not compliant with ISO/IEC 18092
Fingerprinting based on MIFARE type Identification Procedure:
* SmartMX with MIFARE 1K emulation
Other possible matches based on ATQA & SAK values:
* JCOP31 v2.3.1
Try to authenticate to all sectors with default keys...
Symbols: '.' no key found, '/' A key found, '\' B key found, 'x' both keys found
Progress 1 / 5[Key: ffffffffffff] -> [xxxxxxxxxxxxxxxx]
Sector 00 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 01 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 02 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 03 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 04 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 05 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 06 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 07 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 08 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 09 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 10 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 11 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 12 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 13 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 14 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 15 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
We have all sectors encrypted with the default keys..
全部密钥已经找到,读取到一个文件中
Block 63, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 62, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 61, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 60, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 59, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 58, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 57, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 56, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 55, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 54, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 53, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 52, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 51, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 50, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 49, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 48, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 47, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 46, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 45, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 44, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 43, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 42, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 41, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 40, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 39, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 38, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 37, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 36, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 35, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 34, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 33, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 32, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 31, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 30, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 29, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 28, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 27, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 26, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 25, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 24, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 23, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 22, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 21, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 20, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 19, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 18, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 17, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 16, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 15, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 14, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 13, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 12, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 11, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 10, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 09, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 08, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 07, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 06, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 05, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 04, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 03, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 02, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 01, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 00, type A, key ffffffffffff :41  fe  e7  cf  97  28  04  00  90  10  15  01  00  00  00  00
Done, 64  blocks read.
读取完成,总共读取到 64  块数据,如果小于64,可能读取失败,可以尝试重新读取!
##运行完毕##
解卡成功,数据已经加载到A窗口,请及时保存数据,以便后续使用
推荐你备份数据到云端,这样换电脑无忧,同时数据通手机app同步
你可以点击分析数据来分析卡片属于那个系统
系统信息:  CPU模拟卡
发表于 2023-10-3 13:08:09 来自手机 | 只看该作者
CPU模拟卡,可复制但不见得有效。
发表于 2023-10-3 15:06:44 | 只看该作者
CPU模拟卡,IC卡部分没有任何数据,复制不一定可以用
发表于 2023-10-4 20:50:52 | 只看该作者
来学习经验
GMT+8, 2026-4-30 02:46
