查看: 211|回复: 4
自己手动格式化了 现在刷写不了
发表于 2024-9-12 23:11:20 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自己手动格式化了  现在刷写不了
大神帮忙看看
Card type: S50
Found Mifare Classic 1k tag
Uid :E0383100
ISO/IEC 14443A (106 kbps) target:
    ATQA (SENS_RES): 00  04
* UID size: single
* bit frame anticollision supported
       UID (NFCID1): e0  38  31  00
      SAK (SEL_RES): 08
* Not compliant with ISO/IEC 14443-4
* Not compliant with ISO/IEC 18092
Fingerprinting based on MIFARE type Identification Procedure:
* MIFARE Classic 1K
* MIFARE Plus (4 Byte UID or 4 Byte RID) 2K, Security level 1
* SmartMX with MIFARE 1K emulation
Other possible matches based on ATQA & SAK values:
Try to authenticate to all sectors with default keys...
Symbols: '.' no key found, '/' A key found, '\' B key found, 'x' both keys found
  Remains: [32]
[Key: ffffffffffff] -> [xxxxx.x.x.x...xx]
  Remains: [12]
[Key: a0a1a2a3a4a5] -> [xxxxx.x.x.x...xx]
  Remains: [12]
[Key: d3f7d3f7d3f7] -> [xxxxx.x.x.x...xx]
  Remains: [12]
[Key: 000000000000] -> [xxxxx.x.x.x...xx]
  Remains: [12]
[Key: ffff63549854] -> [xxxxx.x.x.x...xx]
  Remains: [12]
[Key: 21191c043010] -> [xxxxx.x.x.x...xx]
  Remains: [12]
[Key: 684774655555] -> [xxxxx.x.x.x/..xx]
  Remains: [11]
[Key: f5d959526452] -> [xxxxx.x.x/x/..xx]
  Remains: [10]
[Key: ff0954e85e62] -> [xxxxx.x.x/x/..xx]
  Remains: [10]
[Key: fff654987255] -> [xxxxx/x.x/x/..xx]
  Remains: [9]
[Key: fffef1546592] -> [xxxxx/x/x/x/..xx]
  Remains: [8]
[Key: fffefef19848] -> [xxxxx/x/x/x/..xx]
  Remains: [8]
[Key: ffff54984654] -> [xxxxx/x/x/x/..xx]
  Remains: [8]
[Key: ffedf854845f] -> [xxxxxxx/x/x/..xx]
  Remains: [7]
[Key: dee6e3fbcfef] -> [xxxxxxx/x/x/..xx]
  Remains: [7]
[Key: e25185412623] -> [xxxxxxx/x/x//.xx]
  Remains: [6]
[Key: ed2564982329] -> [xxxxxxx/x/x//.xx]
  Remains: [6]
[Key: f319545048ff] -> [xxxxxxxxx/x//.xx]
  Remains: [5]
[Key: f541845212ff] -> [xxxxxxxxx/x//.xx]
  Remains: [5]
[Key: feafef965fdd] -> [xxxxxxxxx/x///xx]
  Remains: [4]
[Key: fedfd251591f] -> [xxxxxxxxx/x///xx]
  Remains: [4]
[Key: ff26292b566f] -> [xxxxxxxxx/x///xx]
  Remains: [4]
[Key: ffe128f454e9] -> [xxxxxxxxx/x/x/xx]
  Remains: [3]
[Key: e45846549842] -> [xxxxxxxxx/x/x/xx]
  Remains: [3]
[Key: f648eded1295] -> [xxxxxxxxxxx/x/xx]
  Remains: [2]
[Key: fe5115661789] -> [xxxxxxxxxxx/x/xx]
  Remains: [2]
[Key: fefd51841747] -> [xxxxxxxxxxxxx/xx]
  Remains: [1]
[Key: fefe84984595] -> [xxxxxxxxxxxxx/xx]
  Remains: [1]
[Key: ff2478561565] -> [xxxxxxxxxxxxxxxx]
  Remains: [0]
Sector 00 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 01 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 02 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 03 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 04 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 05 - Found   Key A: fff654987255 Found   Key B: ffedf854845f
Sector 06 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 07 - Found   Key A: fffef1546592 Found   Key B: f319545048ff
Sector 08 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 09 - Found   Key A: f5d959526452 Found   Key B: f648eded1295
Sector 10 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 11 - Found   Key A: 684774655555 Found   Key B: fefd51841747
Sector 12 - Found   Key A: e25185412623 Found   Key B: ffe128f454e9
Sector 13 - Found   Key A: feafef965fdd Found   Key B: ff2478561565
Sector 14 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 15 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
We have all sectors encrypted with the default keys..
Auth with all sectors succeeded, dumping keys to a file!
Block 63, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 62, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 61, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 60, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 59, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 58, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 57, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 56, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 43, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 42, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 41, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 40, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 35, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 34, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 33, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 32, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 27, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 26, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 25, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 24, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 19, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 18, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 17, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 16, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 15, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 14, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 13, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 12, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 11, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 10, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 09, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 08, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 07, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 06, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 05, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 04, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 03, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 02, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 01, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 00, type A, key ffffffffffff :e0  38  31  00  e9  08  04  00  02  e4  2a  c5  cf  d0  f1  1d
INFO: 整体执行时间为(s): 13.000000
------------结束------------
 楼主| 发表于 2024-9-12 23:13:55 来自手机 | 只看该作者
Card type: S50 Found Mifare Classic 1k tag Uid :E0383100 ISO/IEC 14443A (106 kbps) target:     ATQA (SENS_RES): 00  04   * UID size: single * bit frame anticollision supported        UID (NFCID1): e0  38  31  00         SAK (SEL_RES): 08   * Not compliant with ISO/IEC 14443-4 * Not compliant with ISO/IEC 18092  Fingerprinting based on MIFARE type Identification Procedure: * MIFARE Classic 1K * MIFARE Plus (4 Byte UID or 4 Byte RID) 2K, Security level 1 * SmartMX with MIFARE 1K emulation Other possible matches based on ATQA & SAK values:  Try to authenticate to all sectors with default keys... Symbols: '.' no key found, '/' A key found, '\' B key found, 'x' both keys found   Remains: [32] [Key: ffffffffffff] -> [xxxxx.x.x.x...xx]   Remains: [12] [Key: a0a1a2a3a4a5] -> [xxxxx.x.x.x...xx]   Remains: [12] [Key: d3f7d3f7d3f7] -> [xxxxx.x.x.x...xx]   Remains: [12] [Key: 000000000000] -> [xxxxx.x.x.x...xx]   Remains: [12] [Key: ffff63549854] -> [xxxxx.x.x.x...xx]   Remains: [12] [Key: 21191c043010] -> [xxxxx.x.x.x...xx]   Remains: [12] [Key: 684774655555] -> [xxxxx.x.x.x/..xx]   Remains: [11] [Key: f5d959526452] -> [xxxxx.x.x/x/..xx]   Remains: [10] [Key: ff0954e85e62] -> [xxxxx.x.x/x/..xx]   Remains: [10] [Key: fff654987255] -> [xxxxx/x.x/x/..xx]   Remains: [9] [Key: fffef1546592] -> [xxxxx/x/x/x/..xx]   Remains: [8] [Key: fffefef19848] -> [xxxxx/x/x/x/..xx]   Remains: [8] [Key: ffff54984654] -> [xxxxx/x/x/x/..xx]   Remains: [8] [Key: ffedf854845f] -> [xxxxxxx/x/x/..xx]   Remains: [7] [Key: dee6e3fbcfef] -> [xxxxxxx/x/x/..xx]   Remains: [7] [Key: e25185412623] -> [xxxxxxx/x/x//.xx]   Remains: [6] [Key: ed2564982329] -> [xxxxxxx/x/x//.xx]   Remains: [6] [Key: f319545048ff] -> [xxxxxxxxx/x//.xx]   Remains: [5] [Key: f541845212ff] -> [xxxxxxxxx/x//.xx]   Remains: [5] [Key: feafef965fdd] -> [xxxxxxxxx/x///xx]   Remains: [4] [Key: fedfd251591f] -> [xxxxxxxxx/x///xx]   Remains: [4] [Key: ff26292b566f] -> [xxxxxxxxx/x///xx]   Remains: [4] [Key: ffe128f454e9] -> [xxxxxxxxx/x/x/xx]   Remains: [3] [Key: e45846549842] -> [xxxxxxxxx/x/x/xx]   Remains: [3] [Key: f648eded1295] -> [xxxxxxxxxxx/x/xx]   Remains: [2] [Key: fe5115661789] -> [xxxxxxxxxxx/x/xx]   Remains: [2] [Key: fefd51841747] -> [xxxxxxxxxxxxx/xx]   Remains: [1] [Key: fefe84984595] -> [xxxxxxxxxxxxx/xx]   Remains: [1] [Key: ff2478561565] -> [xxxxxxxxxxxxxxxx]   Remains: [0]  Sector 00 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 01 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 02 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 03 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 04 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 05 - Found   Key A: fff654987255 Found   Key B: ffedf854845f Sector 06 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 07 - Found   Key A: fffef1546592 Found   Key B: f319545048ff Sector 08 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 09 - Found   Key A: f5d959526452 Found   Key B: f648eded1295 Sector 10 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 11 - Found   Key A: 684774655555 Found   Key B: fefd51841747 Sector 12 - Found   Key A: e25185412623 Found   Key B: ffe128f454e9 Sector 13 - Found   Key A: feafef965fdd Found   Key B: ff2478561565 Sector 14 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff Sector 15 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff We have all sectors encrypted with the default keys.. Auth with all sectors succeeded, dumping keys to a file! Block 63, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 62, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 61, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 60, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 59, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 58, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 57, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 56, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   -------------------- -------------------- -------------------- -------------------- -------------------- -------------------- -------------------- -------------------- -------------------- Block 43, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 42, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 41, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 40, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   -------------------- -------------------- -------------------- Block 35, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 34, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 33, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 32, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   -------------------- -------------------- -------------------- Block 27, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 26, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 25, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 24, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   -------------------- -------------------- -------------------- Block 19, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 18, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 17, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 16, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 15, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 14, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 13, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 12, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 11, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 10, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 09, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 08, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 07, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 06, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 05, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 04, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 03, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff   Block 02, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 01, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00   Block 00, type A, key ffffffffffff :e0  38  31  00  e9  08  04  00  02  e4  2a  c5  cf  d0  f1  1d    INFO: 整体执行时间为(s): 13.000000  ------------结束------------
发表于 2024-9-13 10:11:40 | 只看该作者
老实的找物业发卡吧 好几个系统
 楼主| 发表于 2024-9-13 23:00:32 来自手机 | 只看该作者
lovemarsh 发表于 2024-9-13 10:11
老实的找物业发卡吧 好几个系统
只有这个办法了吗?   去过物业了 刷卡亮红灯 没反应
发表于 2024-9-24 08:20:03 | 只看该作者
太高深了,看不懂
GMT+8, 2024-11-21 20:06
