查看: 7766|回复: 15
前景1写卡后卡失效了
发表于 2019-2-10 16:52:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前景1的数据 写CUID后卡就失效了读卡显示未检测到卡,连续三张都失效了数据如下
  1. 0 扇区
  2. 0 区块: 5B D4 6B 5C B8 08 04 00 01 8D CF 96 2A B2 C7 1D
  3. 1 区块: 5E 9D 05 48 77 0B FF FF FF FF FF FF FF FF FF FF
  4. 2 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  5. 3 区块: BC FE 01 BC FE 01 FF 07 80 69 FF FF FF FF FF FF
  6. 1 扇区
  7. 0 区块: BC FF 9A 3E FF FF FF FF FF FF 00 FF FF FF FF FF
  8. 1 区块: 00 04 00 00 00 14 14 14 01 03 00 01 00 00 00 C3
  9. 2 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  10. 3 区块: BC FE 01 BC FE 01 FF 07 80 69 FF FF FF FF FF FF
  11. 2 扇区
  12. 0 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  13. 1 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  14. 2 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  15. 3 区块: BC FE 01 BC FE 01 FF 07 80 69 FF FF FF FF FF FF
  16. 3 扇区
  17. 0 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  18. 1 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  19. 2 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  20. 3 区块: BC FE 01 BC FE 01 FF 07 80 69 FF FF FF FF FF FF
  21. 4 扇区
  22. 0 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  23. 1 区块: 00 00 00 00 00 14 14 63 01 01 00 01 00 00 00 EC
  24. 2 区块: BC FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  25. 3 区块: BC FE 01 BC FE 01 FF 07 80 69 FF FF FF FF FF FF
  26. 5 扇区
  27. 0 区块: FF FF FF FF FF FF FF FF BC FF 00 00 63 01 01 00
  28. 1 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  29. 2 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  30. 3 区块: BC FE 01 BC FE 01 FF 07 80 69 FF FF FF FF FF FF
  31. 6 扇区
  32. 0 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  33. 1 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  34. 2 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  35. 3 区块: BC FE 01 BC FE 01 FF 07 80 69 FF FF FF FF FF FF
  36. 7 扇区
  37. 0 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  38. 1 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  39. 2 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  40. 3 区块: BC FE 01 BC FE 01 FF 07 80 69 FF FF FF FF FF FF
  41. 8 扇区
  42. 0 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  43. 1 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  44. 2 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  45. 3 区块: FF FF FF FF FF FF FF 07 80 69 FF FF FF FF FF FF
  46. 9 扇区
  47. 0 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  48. 1 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  49. 2 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  50. 3 区块: FF FF FF FF FF FF FF 07 80 69 FF FF FF FF FF FF
  51. 10 扇区
  52. 0 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  53. 1 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  54. 2 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  55. 3 区块: FF FF FF FF FF FF FF 07 80 69 FF FF FF FF FF FF
  56. 11 扇区
  57. 0 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  58. 1 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  59. 2 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  60. 3 区块: FF FF FF FF FF FF FF 07 80 69 FF FF FF FF FF FF
  61. 12 扇区
  62. 0 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  63. 1 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  64. 2 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  65. 3 区块: FF FF FF FF FF FF FF 07 80 69 FF FF FF FF FF FF
  66. 13 扇区
  67. 0 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  68. 1 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  69. 2 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  70. 3 区块: FF FF FF FF FF FF FF 07 80 69 FF FF FF FF FF FF
  71. 14 扇区
  72. 0 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  73. 1 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  74. 2 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  75. 3 区块: FF FF FF FF FF FF FF 07 80 69 FF FF FF FF FF FF
  76. 15 扇区
  77. 0 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  78. 1 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  79. 2 区块: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  80. 3 区块: FF FF FF FF FF FF FF 07 80 69 FF FF FF FF FF FF
复制代码
发表于 2019-2-10 17:33:12 | 只看该作者
有错误呗
需要大神出手
发表于 2019-2-10 17:40:03 | 只看该作者
赞赞 顶顶 只为抽奖更顺利
发表于 2019-2-10 18:30:24 | 只看该作者
我只是领取软件的,啥数据不会哦
发表于 2019-2-10 18:55:27 | 只看该作者
谢谢楼主,共同发
发表于 2019-2-10 19:20:32 | 只看该作者
我是个凑数的。。。
发表于 2019-2-10 22:22:50 | 只看该作者
楼主改数据后直接写入原卡试试。卡片失效有可能是控制位有问题。但是看数据控制位没问题。你是复制完刷卡之后失效了吧?如果是刷卡之后失效,有可能是系统防复制机制检测到复制卡,把复制卡的控制位改掉!
 楼主| 发表于 2019-2-11 16:30:23 | 只看该作者
yuwenyongfei 发表于 2019-2-10 22:22
楼主改数据后直接写入原卡试试。卡片失效有可能是控制位有问题。但是看数据控制位没问题。你是复制完刷卡之 ...
感谢回复,我是直接复制的原卡数据,写完卡后我直接读卡就已经显示未识别到卡片,还没来得及去电梯测试
发表于 2019-2-11 18:29:38 | 只看该作者
如果控制位弄错了造成不识别就没救了,如果是卡号校验弄错了也会造成卡片不识别,可以用叠卡方式恢复。
发表于 2019-2-11 18:30:07 | 只看该作者
估计是你写卡时导入的数据有问题!
GMT+8, 2026-5-22 05:55
