查看: 2504|回复: 15
各位高手,这个卡可以延期吗?
发表于 2023-12-9 09:57:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*********开始执行MFOC解密*********
The custom key 0x000102030497 has been added to the default keys
High perfermance mode!
ERROR: 第一段后门开启命令执行失败!
高速PCR532 IC ID 设备,SVIP极速解卡,可以秒解大部分卡
Found Mifare Classic 1k tag
Uid :FEC9962A
ISO/IEC 14443A (106 kbps) target:
    ATQA (SENS_RES): 00  04
* UID size: single
* bit frame anticollision supported
       UID (NFCID1): fe  c9  96  2a
      SAK (SEL_RES): 08
* Not compliant with ISO/IEC 14443-4
* Not compliant with ISO/IEC 18092
Fingerprinting based on MIFARE type Identification Procedure:
* MIFARE Classic 1K
* MIFARE Plus (4 Byte UID or 4 Byte RID) 2K, Security level 1
* SmartMX with MIFARE 1K emulation
Other possible matches based on ATQA & SAK values:
Try to authenticate to all sectors with default keys...
Symbols: '.' no key found, '/' A key found, '\' B key found, 'x' both keys found
Progress 1 / 6[Key: ffffffffffff] -> [x...xxxxxxxxxxxx]
Progress 2 / 6[Key: a0a1a2a3a4a5] -> [x...xxxxxxxxxxxx]
Progress 3 / 6[Key: 000000000000] -> [x...xxxxxxxxxxxx]
Progress 4 / 6[Key: 000102030497] -> [xxxxxxxxxxxxxxxx]
Sector 00 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 01 - Found   Key A: 000102030497 Found   Key B: 000102030497
Sector 02 - Found   Key A: 000102030497 Found   Key B: 000102030497
Sector 03 - Found   Key A: 000102030497 Found   Key B: 000102030497
Sector 04 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 05 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 06 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 07 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 08 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 09 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 10 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 11 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 12 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 13 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 14 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 15 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
We have all sectors encrypted with the default keys..
全部密钥已经找到,读取到一个文件中
Block 63, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 62, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 61, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 60, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 59, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 58, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 57, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 56, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 55, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 54, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 53, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 52, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 51, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 50, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 49, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 48, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 47, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 46, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 45, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 44, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 43, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 42, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 41, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 40, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 39, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 38, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 37, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 36, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 35, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 34, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 33, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 32, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 31, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 30, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 29, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 28, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 27, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 26, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 25, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 24, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 23, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 22, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 21, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 20, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 19, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 18, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 17, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 16, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 15, type A, key 000102030497 :00  01  02  03  04  97  ff  07  80  69  00  01  02  03  04  97
Block 14, type A, key 000102030497 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 13, type A, key 000102030497 :ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff
Block 12, type A, key 000102030497 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 11, type A, key 000102030497 :00  01  02  03  04  97  ff  07  80  69  00  01  02  03  04  97
Block 10, type A, key 000102030497 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 09, type A, key 000102030497 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 08, type A, key 000102030497 :ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  a5  ff  5a
Block 07, type A, key 000102030497 :00  01  02  03  04  97  ff  07  80  69  00  01  02  03  04  97
Block 06, type A, key 000102030497 :ff  f8  a7  ce  bb  cf  ef  6b  ef  e3  61  4b  e3  5b  eb  00
Block 05, type A, key 000102030497 :57  47  cf  0b  f7  e3  ff  ff  00  0a  46  51  1b  aa  70  06
Block 04, type A, key 000102030497 :ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  a5  ff  5a
Block 03, type A, key ffffffffffff :ff  ff  ff  ff  ff  ff  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 02, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 01, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 00, type A, key ffffffffffff :fe  c9  96  2a  8b  08  04  00  62  63  64  65  66  67  68  69
Done, 64  blocks read.
读取完成,总共读取到 64  块数据,如果小于64,可能读取失败,可以尝试重新读取!
##运行完毕##
解卡成功,数据已经加载到A窗口,请及时保存数据,以便后续使用
推荐你备份数据到云端,这样换电脑无忧,同时数据通手机app同步
你可以点击分析数据来分析卡片属于那个系统
系统信息:  邦瑞6/7代
发表于 2023-12-9 17:19:36 | 只看该作者
那就邦瑞6/7代 搞起来啊~
发表于 2023-12-9 18:19:21 | 只看该作者
0 区块: FE C9 96 2A 8B 08 04 00 62 63 64 65 66 67 68 69
0 区块: FF FF FF FF FF FF FF FF FF FF FF FF FF A5 FF 5A
1 区块: 57 47 CF 0B F7 E3 FF FF 00 0A 46 51 1B AA 70 06
2 区块: FF F8 A7 CE BB CF EF 6B EF E3 61 4B E3 5B EB 00
3 区块: 00 01 02 03 04 97 FF 07 80 69 00 01 02 03 04 97
发表于 2023-12-10 14:42:54 | 只看该作者
小手一抖,积分到手
发表于 2023-12-10 16:44:17 | 只看该作者
手一抖,积分到手
发表于 2023-12-10 21:34:43 | 只看该作者
不要沉下去了呀,我都帮楼主把数据整理然后发出来了。 大神给力一点哦~
发表于 2023-12-10 23:12:04 | 只看该作者
24年一月4到期啊
发表于 2023-12-12 10:01:05 | 只看该作者
感谢楼主分享
GMT+8, 2026-4-29 21:54
