查看: 6254|回复: 12
为什么复制的卡不能用?
发表于 2018-9-6 20:43:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题。为什么复制的卡不能用?
Found Mifare Classic 1k tag
CardUID = A7BD6866
CardInfo = 16-63
ISO/IEC 14443A (106 kbps) target:
    ATQA (SENS_RES): 00  04
* UID size: single
* bit frame anticollision supported
       UID (NFCID1): a7  bd  68  66
      SAK (SEL_RES): 08
* Not compliant with ISO/IEC 14443-4
* Not compliant with ISO/IEC 18092
Fingerprinting based on MIFARE type Identification Procedure:
* MIFARE Classic 1K
* MIFARE Plus (4 Byte UID or 4 Byte RID) 2K, Security level 1
* SmartMX with MIFARE 1K emulation
Other possible matches based on ATQA & SAK values:
Try to authenticate to all sectors with default keys...
Symbols: '.' no key found, '/' A key found, '\' B key found, 'x' both keys found
[Key: ffffffffffff] -> [xxxxxxxxxx...xxx]
[Key: 000000000000] -> [xxxxxxxxxx...xxx]
[Key: a0a1a2a3a4a5] -> [xxxxxxxxxx...xxx]
[Key: 8fd0a4f256e9] -> [xxxxxxxxxx...xxx]
Sector 00 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 01 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 02 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 03 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 04 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 05 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 06 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 07 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 08 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 09 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 10 - Unknown Key A               Unknown Key B
Sector 11 - Unknown Key A               Unknown Key B
Sector 12 - Unknown Key A               Unknown Key B
Sector 13 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 14 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 15 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Using sector 00 as an exploit sector
Sector: 10, type A, probe 0, distance 13129 .....
Sector: 10, type A, probe 1, distance 13125 .....
Sector: 10, type A, probe 2, distance 12971 .....
Sector: 10, type A, probe 3, distance 13223 .....
Sector: 10, type A, probe 4, distance 13271 .....
Sector: 10, type A, probe 5, distance 13227 .....
Sector: 10, type A, probe 6, distance 12973 .....
Sector: 10, type A, probe 7, distance 13127 .....
Sector: 10, type A, probe 8, distance 13275 .....
Sector: 10, type A, probe 9, distance 13023 .....
Sector: 10, type A, probe 10, distance 13221 .....
Sector: 10, type A, probe 11, distance 13029 .....
Sector: 10, type A, probe 12, distance 13229 .....
Sector: 10, type A, probe 13, distance 13227 .....
Sector: 10, type A, probe 14, distance 13373 .....
Sector: 10, type A, probe 15, distance 13229 .....
Sector: 10, type A, probe 16, distance 13419 .....
Sector: 10, type A, probe 17, distance 13079 .....
Sector: 10, type A, probe 18, distance 13171 .....
Sector: 10, type A, probe 19, distance 13229 .....
Sector: 10, type A, probe 20, distance 13171 .....
Sector: 10, type A, probe 21, distance 13127 .....
Sector: 10, type A, probe 22, distance 13221 .....
Sector: 10, type A, probe 23, distance 13275 .....
Sector: 10, type A, probe 24, distance 13273 .....
Sector: 10, type A, probe 25, distance 13323 .....
Sector: 10, type A, probe 26, distance 13279 .....
Sector: 10, type A, probe 27, distance 13327 .....
Sector: 10, type A, probe 28, distance 13323 .....
Sector: 10, type A, probe 29, distance 13327 .....
Sector: 10, type A, probe 30, distance 13129 .....
Sector: 10, type A, probe 31, distance 13325 .....
Sector: 10, type A, probe 32, distance 13269 .....
Sector: 10, type A, probe 33, distance 13127 .....
Sector: 10, type A, probe 34, distance 13267 .....
Sector: 10, type A, probe 35, distance 13077 .....
Sector: 10, type A, probe 36, distance 13185 .....
Sector: 10, type A, probe 37, distance 13179 .....
  Found Key: A [b6d868e2c488]
  Data read with Key A revealed Key B: [b6d868e2c488] - checking Auth: OK
Sector: 11, type A
Sector: 12, type A
Auth with all sectors succeeded, dumping keys to a file!
Block 63, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 62, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 61, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 60, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 59, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 58, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 57, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 56, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 55, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 54, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 53, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 52, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 51, type A, key b6d868e2c488 :00  00  00  00  00  00  ff  07  80  69  b6  d8  68  e2  c4  88
Block 50, type A, key b6d868e2c488 :bf  e2  e3  f4  d1  44  6e  32  6b  2e  8c  ec  68  ef  1a  22
Block 49, type A, key b6d868e2c488 :90  0e  37  2c  34  ca  2f  b3  3c  86  3f  73  02  8c  64  4e
Block 48, type A, key b6d868e2c488 :ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff  ff
Block 47, type A, key b6d868e2c488 :00  00  00  00  00  00  ff  07  80  69  b6  d8  68  e2  c4  88
Block 46, type A, key b6d868e2c488 :0c  00  00  00  0e  cc  cc  00  00  00  00  0c  04  c0  cd  0c
Block 45, type A, key b6d868e2c488 :70  08  00  00  50  00  60  00  04  0c  00  00  00  00  40  00
Block 44, type A, key b6d868e2c488 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 43, type A, key b6d868e2c488 :00  00  00  00  00  00  ff  07  80  69  b6  d8  68  e2  c4  88
Block 42, type A, key b6d868e2c488 :00  04  4d  84  90  00  02  00  00  00  01  00  c9  00  00  00
Block 41, type A, key b6d868e2c488 :dc  f8  c8  8d  94  1d  49  4d  f1  fd  ef  96  8d  6f  a9  d9
Block 40, type A, key b6d868e2c488 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 39, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 38, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 37, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 36, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 35, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 34, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 33, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 32, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 31, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 30, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 29, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 28, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 27, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 26, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 25, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 24, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 23, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 22, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 21, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 20, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 19, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 18, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 17, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 16, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 15, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 14, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 13, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 12, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 11, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 10, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 09, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 08, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 07, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 06, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 05, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 04, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 03, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 02, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 01, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 00, type A, key ffffffffffff :a7  bd  68  66  14  08  04  00  01  4d  13  74  95  0a  ee  1d
00 扇区
00区块: A7BD686614080400014D1374950AEE1D
01区块: 00000000000000000000000000000000
02区块: 00000000000000000000000000000000
03区块: FFFFFFFFFFFFFF078069FFFFFFFFFFFF
01 扇区
00区块: 00000000000000000000000000000000
02 扇区
03 扇区
04 扇区
05 扇区
06 扇区
07 扇区
08 扇区
09 扇区
01区块: DCF8C88D941D494DF1FDEF968D6FA9D9
02区块: 00044D849000020000000100C9000000
03区块: B6D868E2C488FF078069B6D868E2C488
01区块: 7008000050006000040C000000004000
02区块: 0C0000000ECCCC000000000C04C0CD0C
00区块: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
01区块: 900E372C34CA2FB33C863F73028C644E
02区块: BFE2E3F4D1446E326B2E8CEC68EF1A22
发表于 2018-9-6 21:33:54 | 只看该作者
你用的的是什么卡复制的是什么数据,要看一看的。
发表于 2018-9-6 21:37:06 | 只看该作者
要看你复制的卡是不是防复制防穿的,有些梯控系统是需要用那种防复制的卡才可以,我也是新人,我是重复实验过才知道的,如果赶上你家是滚动梯控系统的话我就不知道该怎么办了,还在学习中,滚动的现在基本上是复制之后原卡不好用只能好用一张,最后使用的一张好使
bucuo 不错  发表于 2018-9-6 21:39
发表于 2018-9-6 21:51:33 | 只看该作者
过来看看的
发表于 2018-9-6 22:31:18 | 只看该作者
数据发一下看看,是什么系统?
发表于 2018-9-6 23:52:28 | 只看该作者
原因太多了,只有用数据说话了,发出了让大家看看呗
 楼主| 发表于 2018-9-7 18:00:07 | 只看该作者
数据上传了
 楼主| 发表于 2018-9-7 18:00:40 | 只看该作者
数据上传了
 楼主| 发表于 2018-9-7 18:01:20 | 只看该作者
zaim891456898 发表于 2018-9-6 22:31
数据发一下看看,是什么系统?
数据上传了 帮忙看下,谢谢
 楼主| 发表于 2018-9-7 18:02:43 | 只看该作者
pianzigun 发表于 2018-9-6 21:37
要看你复制的卡是不是防复制防穿的,有些梯控系统是需要用那种防复制的卡才可以,我也是新人,我是重复实验 ...
啥也不懂,只是好奇 没好使
GMT+8, 2026-6-20 09:26
