查看: 5773|回复: 16
各位大虾帮忙看下日期
发表于 2018-9-4 23:02:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Found Mifare Classic 1k tag
CardUID = 115572DC
CardInfo = 16-63
ISO/IEC 14443A (106 kbps) target:
    ATQA (SENS_RES): 00  04
* UID size: single
* bit frame anticollision supported
       UID (NFCID1): 11  55  72  dc
      SAK (SEL_RES): 08
* Not compliant with ISO/IEC 14443-4
* Not compliant with ISO/IEC 18092
Fingerprinting based on MIFARE type Identification Procedure:
* MIFARE Classic 1K
* MIFARE Plus (4 Byte UID or 4 Byte RID) 2K, Security level 1
* SmartMX with MIFARE 1K emulation
Other possible matches based on ATQA & SAK values:
Try to authenticate to all sectors with default keys...
Symbols: '.' no key found, '/' A key found, '\' B key found, 'x' both keys found
[Key: ffffffffffff] -> [x..xxxxx\xxxxxxx]
[Key: 000000000000] -> [x..xxxxx\xxxxxxx]
[Key: a0a1a2a3a4a5] -> [x..xxxxx\xxxxxxx]
[Key: 8fd0a4f256e9] -> [x..xxxxx\xxxxxxx]
Sector 00 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 01 - Unknown Key A               Unknown Key B
Sector 02 - Unknown Key A               Unknown Key B
Sector 03 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 04 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 05 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 06 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 07 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 08 - Unknown Key A               Found   Key B: ffffffffffff
Sector 09 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 10 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 11 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 12 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 13 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 14 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Sector 15 - Found   Key A: ffffffffffff Found   Key B: ffffffffffff
Using sector 00 as an exploit sector
Sector: 1, type A, probe 0, distance 1622 .....
Sector: 1, type A, probe 1, distance 1646 .....
  Found Key: A [013889343891]
  Data read with Key A revealed Key B: [013889343891] - checking Auth: OK
Sector: 2, type A
Sector: 8, type A, probe 0, distance 1653 .....
Sector: 8, type A, probe 1, distance 1628 .....
  Found Key: A [5465768798a9]
Auth with all sectors succeeded, dumping keys to a file!
Block 63, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 62, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 61, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 60, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 59, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 58, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 57, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 56, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 55, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 54, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 53, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 52, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 51, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 50, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 49, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 48, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 47, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 46, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 45, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 44, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 43, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 42, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 41, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 40, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 39, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 38, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 37, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 36, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 35, type A, key 5465768798a9 :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 34, type A, key 5465768798a9 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  0b  16
Block 33, type A, key 5465768798a9 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 32, type A, key 5465768798a9 :00  00  00  00  bb  00  00  00  00  00  00  00  00  00  00  00
Block 31, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 30, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 29, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 28, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 27, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 26, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 25, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 24, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 23, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 22, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 21, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 20, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 19, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 18, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 17, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 16, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 15, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 14, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 13, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 12, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 11, type A, key 013889343891 :00  00  00  00  00  00  ff  07  80  69  01  38  89  34  38  91
Block 10, type A, key 013889343891 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 09, type A, key 013889343891 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 08, type A, key 013889343891 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 07, type A, key 013889343891 :00  00  00  00  00  00  ff  07  80  69  01  38  89  34  38  91
Block 06, type A, key 013889343891 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 05, type A, key 013889343891 :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  10
Block 04, type A, key 013889343891 :19  11  22  12  34  03  4f  00  11  00  00  00  00  00  f3  ce
Block 03, type A, key ffffffffffff :00  00  00  00  00  00  ff  07  80  69  ff  ff  ff  ff  ff  ff
Block 02, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 01, type A, key ffffffffffff :00  00  00  00  00  00  00  00  00  00  00  00  00  00  00  00
Block 00, type A, key ffffffffffff :11  55  72  dc  ea  08  04  00  01  8e  60  59  d8  6a  10  1d
0区块:115572DCEA080400018E6059D86A101D
0区块:1911221234034F00110000000000F3CE
1区块:00000000000000000000000000000010
3区块:013889343891FF078069013889343891
0区块:00000000BB0000000000000000000000
2区块:00000000000000000000000000000B16
3区块:5465768798A9FF078069FFFFFFFFFFFF
发表于 2018-9-5 01:26:18 | 只看该作者
223
发表于 2018-9-5 01:54:57 | 只看该作者
前排支持下分享
没看完~~~~~~ 先顶,好同志
发表于 2018-9-5 02:23:28 | 只看该作者
不错不错辛苦了。。。
发表于 2018-9-5 02:51:39 | 只看该作者
前排支持下
发表于 2018-9-5 06:42:52 | 只看该作者
感觉:1 扇区
这里像
发表于 2018-9-5 08:19:35 | 只看该作者
191122日期  F3CE效验位,需要修改联系我
发表于 2018-9-5 08:24:05 | 只看该作者
19 12 31 12 34 03 4F 00 11 00 00 00 00 00 95 55延期一个月
发表于 2018-9-5 14:41:40 | 只看该作者
必须把基础知识学好。
GMT+8, 2026-5-2 03:29
