查看: 10716|回复: 20
CPU卡操作函数
发表于 2018-4-20 11:06:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CPU卡与传统的MifareOne系列卡相比,具有更加安全、复杂的认证机制,这就意味着CPU卡的读写操作在软件开发中变得更加的复杂。我们这些复杂的操作封装成5个通用的函数,与我们的CPU读写器相结合,让您十分钟就搞定CPU的读写操作。
       //'CPU卡寻卡及将卡复位到14443A-4的指令状态
        [DllImport("OUR_MIFARE.dll", EntryPoint = "cpurequest")]
        static extern byte cpurequest(byte[] serial, byte[] param, byte[] cosver, byte[] code);
        //初始化函数,(ctrlword是否需要先清空卡,不需要清空的话,可以需输入卡密码,卡密码长度)ctrlword_0是否先清空卡,分配空间(字节数),
        //Public Declare Function cpursinit Lib "OUR_MIFARE.dll" (ByVal ctrlword As Byte, ByVal key As Long, ByVal keylen As Byte, ByVal customsize As Long) As Byte
        [DllImport("OUR_MIFARE.dll", EntryPoint = "cpursinit", CallingConvention = CallingConvention.StdCall)]
        static extern byte cpursinit(byte ctrlword, byte[] key, byte[] keylen, Int32 customsize);
        //增加文件(文件序号0~5,文件只读密码:长度,文件读写密码,长度,分配空间)
        //Public Declare Function cpursfileadd Lib "OUR_MIFARE.dll" (ByVal fileno As Byte, ByVal readonlykey As Long, ByVal readonlykeylen As Byte, ByVal writekey As Long, ByVal writekeylen As Byte, ByVal customsize As Long) As Byte
        [DllImport("OUR_MIFARE.dll", EntryPoint = "cpursfileadd", CallingConvention = CallingConvention.StdCall)]
        static extern byte cpursfileadd(byte fileno, byte[] readonlykey, byte[] readonlykeylen, byte[] writekey, byte[] writekeylen, Int32 customsize);
        //'修改文件密码,修改后,请妥慎记住,否则该文件将无法再用
        //Public Declare Function cpursfilekeychg Lib "OUR_MIFARE.dll" (ByVal fileno As Byte, ByVal keytype As Byte, ByVal oldkey As Long, ByVal oldkeylen As Byte, ByVal newkey As Long, ByVal newkeylen As Byte) As Byte
        [DllImport("OUR_MIFARE.dll", EntryPoint = "cpursfilekeychg", CallingConvention = CallingConvention.StdCall)]
        static extern byte cpursfilekeychg(byte fileno, byte keytype, byte[] oldkey, byte[] oldkeylen, byte[] newkey, byte[] newkeylen);
        //'修改卡密码,卡密码和文件没有任何关系,卡密码只是用来清空卡,读和写文件是无效的。
        //Public Declare Function cpurscardkeychg Lib "OUR_MIFARE.dll" (ByVal oldkey As Long, ByVal oldkeylen As Byte, ByVal newkey As Long, ByVal newkeylen As Byte) As Byte
        [DllImport("OUR_MIFARE.dll", EntryPoint = "cpurscardkeychg", CallingConvention = CallingConvention.StdCall)]
        static extern byte cpurscardkeychg(byte fileno, byte[] readonlykey, byte[] readonlykeylen, byte[] writekey, byte[] writekeylen, Int32 customsize);
        //读文件数据(文件序号,读写密码,密码长度,读取起始位置,读取长度,读出内容)
        //Public Declare Function cpursfiledataread Lib "OUR_MIFARE.dll" (ByVal fileno As Byte, ByVal keytype As Byte, ByVal key As Long, ByVal keylen As Byte, ByVal startaddr As Long, ByVal databuf As Long, ByVal datalen As Long) As Byte
        [DllImport("OUR_MIFARE.dll", EntryPoint = "cpursfiledataread", CallingConvention = CallingConvention.StdCall)]
        static extern byte cpursfiledataread(byte fileno, byte keytype, byte[] rwkey, byte[] rwkeylen, Int32 startaddr, byte[] databuf, Int32 datalen);
        //写文件数据(文件序号,文件读写密码,密码长度,写入起始位置,写入长度,写入内容)
        //Public Declare Function cpursfiledatawrite Lib "OUR_MIFARE.dll" (ByVal fileno As Byte, ByVal keytype As Byte, ByVal key As Long, ByVal keylen As Byte, ByVal startaddr As Long, ByVal databuf As Long, ByVal datalen As Long) As Byte
        [DllImport("OUR_MIFARE.dll", EntryPoint = "cpursfiledatawrite", CallingConvention = CallingConvention.StdCall)]
        static extern byte cpursfiledatawrite(byte fileno, byte keytype, byte[] rwkey, byte[] rwkeylen, Int32 startaddr, byte[] databuf, Int32 datalen);
        //修改卡密码,卡密码和文件没有任何关系,卡密码只是用来清空卡,读和写文件是无效的。
        static extern byte cpurscardkeychg(byte[] oldkey, byte[] oldlen, byte[] newkey, byte[] newlen);
来自网络
发表于 2018-4-20 11:13:50 | 只看该作者
有点高深了,不适合普通IC爱好者!
适合那些开发者
发表于 2018-4-20 11:26:14 | 只看该作者
看不懂啊 ,来点实际的呗
发表于 2018-4-20 11:42:24 | 只看该作者
我们只需要看懂每个电梯卡的数据(复制大家都会了)。知道怎么修改数据就OK了,开发数据就免了。
发表于 2018-4-21 19:41:28 来自手机 | 只看该作者
谢谢,学习了
发表于 2018-4-21 19:51:43 | 只看该作者
我说怎么疾风   都是疾风  还是疾风   跟着疾风来学习  赚积分
发表于 2018-4-22 00:29:20 | 只看该作者
这个我觉得这辈子我都不愿意去研究
发表于 2018-4-22 07:31:45 | 只看该作者
谢谢,学习了
GMT+8, 2026-4-30 12:56
