查看: 126|回复: 10
新人求助格式化卡片
发表于 2024-4-17 17:24:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
作为一位新晋求教者,我曾向一张空白的 CUID 卡片中输入了以下数据。遗憾的是,由于卡片数量不足,我希望能够重复使用这张卡片并再次进行写入操作。然而,在执行此步骤之前,需要对卡片进行格式化处理呢,由此带来的问题是,在格式化之前需要对卡片进行读取操作,而这个过程可能会持续较长时间。我记得我在输入的数据中有一个密钥,如果能够将其提取出来,并将其加入到我自己的密钥库中,那么解密的速度将会大大提升。然而,我对此并不熟悉,因此恳请各位热心网友伸出援手。如果可能的话,不仅请告知我密钥,还请告诉我具体的操作方法,我非常愿意学习。以下是我输入的原始数据,再次感谢大家的帮助。
  1. 0扇区
  2. B7 F9 61 53 7C 08 04 00 C2 F3 CC EF D6 FA CA D6
  3. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  4. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  5. C2 F3 CC EF A1 14 FF 07 80 69 D6 FA CA D6 FA 35
  6. 1扇区
  7. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  8. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  9. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  10. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  11. 2扇区
  12. 01 00 00 00 64 00 00 00 01 00 00 00 00 00 00 00
  13. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  14. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  15. 44 4E 41 4B 45 53 FF 07 80 69 44 4E 41 4B 45 53
  16. 3扇区
  17. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  18. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  19. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  20. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  21. 4扇区
  22. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  23. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  24. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  25. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  26. 5扇区
  27. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  28. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  29. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  30. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  31. 6扇区
  32. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  33. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  34. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  35. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  36. 7扇区
  37. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  38. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  39. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  40. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  41. 8扇区
  42. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  43. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  44. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  45. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  46. 9扇区
  47. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  48. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  49. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  50. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  51. 10扇区
  52. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  53. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  54. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  55. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  56. 11扇区
  57. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  58. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  59. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  60. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  61. 12扇区
  62. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  63. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  64. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  65. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  66. 13扇区
  67. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  68. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  69. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  70. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  71. 14扇区
  72. 12 24 00 00 00 00 19 02 0D 0F 00 00 00 00 00 A1
  73. 20 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00
  74. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  75. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
  76. 15扇区
  77. 25 26 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  78. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  79. FF FF 00 A5 00 00 00 00 00 00 00 00 00 00 00 00
  80. AB CD 06 13 09 04 FF 07 80 69 AB CD 06 13 09 04
复制代码
发表于 2024-4-17 18:40:23 | 只看该作者
你字打了很多,我来解答一下:
1、需要收集的秘钥,我这边直接告诉你。你也可以使用软件直接提取秘钥(具体提取方法,付费教学)
  1. C2F3CCEFA114
  2. D6FACAD6FA35
  3. ABCD06130904
  4. 444E414B4553
复制代码
2、格式化方法,以PCR532为例,先【编辑历史秘钥】将上门收集的秘钥添加到文件中并保存。然后【更新秘钥库】软件提示更新秘钥库成功。再然后,点击IC操作区的【格式化】,即可格式化成功。(图文或视频付费教学)
3、你可能遇到的问题,CUID卡本身存在后门漏洞,PCR532软件可以直接解码秘钥,理论上可以直接格式化,与你知不知道秘钥无关。其次,如果不是CUID卡,而是FUID,UFUID卡,那么0扇区0块的数据,卡的特性决定它是无法修改。第三,因为众所周知的原因,写死控制位,导致无法读取或格式化的情况也是存在的,这样就不必纠结,直接换卡即可。
4、点到为止,希望对你的学习有所帮助。
我大哥就是好人,还负责教学  发表于 2024-4-17 23:30
发表于 2024-4-17 18:19:14 来自手机 | 只看该作者
麦田发的卡自己研究
发表于 2024-4-17 23:31:19 | 只看该作者
麦田数据,自行研究吧,既然有软件改,还不知道卡密是哪些吗
 楼主| 发表于 2024-4-18 14:06:23 | 只看该作者
nkzxlgq 发表于 2024-4-17 18:40
你字打了很多,我来解答一下:
1、需要收集的秘钥,我这边直接告诉你。你也可以使用软件直接提取秘钥(具 ...
谢谢大佬,我打字了很多,说话不简洁,你还耐心解答,甚是感谢
 楼主| 发表于 2024-4-18 15:58:27 | 只看该作者
朋友,我新手,这不是笑话我呢嘛,我是真不会,不过也谢谢你回帖。
发表于 2024-4-18 17:20:48 | 只看该作者
卡密就是每个扇区数据第4行,
前6字节是A秘钥,
后6字节是B秘钥,
中间的FF078069,是控制位,
如果不懂不要瞎改,改不好这张卡就彻底作废,只能扔到垃圾箱里解决问题了
 楼主| 发表于 2024-4-19 14:50:00 | 只看该作者
fsjt7910 发表于 2024-4-18 17:20
卡密就是每个扇区数据第4行,前6字节是A秘钥,
后6字节是B秘钥,
中间的FF078069,是控制位,
谢谢前辈,我刚把这些存到我印象笔记里了,又学了一个知识点,谢谢前辈。
发表于 2024-4-19 17:41:34 | 只看该作者
慢慢学习,可以加我联系方式一起学习讨论
发表于 6 天前 | 只看该作者
如卡数据不用,M1工具直接格
GMT+8, 2024-5-18 02:27
